Configure ACE Internet Control Message Protocol (ICMP) message type entries to have the filter look for packets of a specific ICMP message type.
The ACL exists.
The ACE exists.
- Select Advanced Filters (ACE/ACLs).
- Select the ACL tab.
- Select the appropriate ACL.
- Select ACE.
- Select the appropriate ACE.
- Select Proto.
- Select the Icmp Msg Type tab.
- Select Insert.
- Specify the operator for the ICMP message type.
- In the List box, specify the ICMP messages to match.
- Select Insert.
Icmp Msg Type Field Descriptions
Use the data in the following table to use the Icmp Msg Type tab.
Name |
Description |
AclId |
Specifies the ACL ID. |
AceId |
Specifies the ACE ID. |
Oper |
Specifies the operator for the ACE protocol ICMP message type. Equal (eq) is the only option. |
List |
Specifies the ICMP message type (0–255), or echoreply, destunreach, sourcequench, redirect, echo-request, routeradv, routerselect, time-exceeded, param-problem, timestamp-request, timestamp-reply, addressmask-request, addressmask-reply, or traceroute. |
